Hey guys!
I've been working on the old SN trying to get ready for the season. I've got some more questions about the cooling setup.
From my understanding, normally the cooling line comes from the pump, into the manifold, out the head, and into the exhaust. Mine aren't doing that.
Reading
this post, I see there are multiple ways things can be setup. Mine doesn't match any of them, but it's closest to the "Independent cooling B-pipe style".
The manifold has been tapped for two inputs and a tee feeding them.
My head has 5 outlets (one of them plugged) and all 4 of them go to the pissers in the tray.
On the head pipe (I think that's what it's called) there are two barbs. I've seen pictures that have two and others that have three, so I'm a bit confused.
The way it was plumbed up, both barbs from the head pipe were tied together with a tee, fed down to the stinger, and split with another tee to a pisser.
So, how is the exhaust getting any water? Is it coming through the manifold? I've been avoiding pulling it apart as I don't have any new gaskets.
I've seen some posts about running things restricted to reduce the amount of water for added performance. From the amount of water coming out of the side pisser, things seem pretty restricted.
Also, I've found some burning in the fiberglass around the waterbox, so maybe it's too dry? I plan to put the thermometer on it this season to see what it's at.
When I put things back together, I just want to ensure things are safe. I'd like to keep the tray pissers, but I'll clean up that piping, it's a mess
