- CT
Its not different, in fact its the same. (we make the plate for them)Whats the difference between the Rad Dudes Power Factor pipe conversion plate and the Power Factor pipe conversion plate? Is the quality the same since the price is the same?
There wasnt a part on the market (that worked with dasa and stock) so we made one so the kawi guys could get to use an awesome pipe like the Power Factor!
Rad Dudes works very hard to be the first to make things that are not out there. Thats why we take it to heart when someone tries to copy one of our ideas, and then makes a inferior product....
If you are going to copy something go ahead, just improve it! The ground work is there, if you go out and make it better and cheaper that is awesome. Just dont make is cheaper and sacrifice the quality of the product.
To be on topic here. If the hull changes were for pump design and fitting big yami pumps and Kawi pumps its great, keep pushing the sport! Maybe give the body lines alittle change so people dont call it a copy
