retroicon
XX-xx-XX-xx-XX
Hey Everyone,
Thanks in advance for any help you can provide... I'm lost at this point.
I had a motor rebuilt a while ago (a few years) and just finally found the time to put it back into my Blaster. It's a 62t, dual 44's, MSD Enhancer, Lightened Flywheel (Zero), 4mil stroker (plate), Girdled head (185 compression), Factory Blaster pipe, coil from JSS.
The motor was rebuilt with new rings, fresh hone, carbs rebuilt, new Enhancer, all new fuel lines.
Leakdown test is good, compression is good, I can see fuel running through the lines to the carb (see it through inline fuel filters), I have strong spark on both cylinders. I can also hear fuel going through the return line, and dropping into the tank which seems to indicate that the carbs are pumping plenty of fuel.
The primer is on the return line, and when I open the gas cap after trying to start it for 20-30 seconds, I'm getting that "vacuum" sound that indicates the tank is pressurized.
If I put a couple of drops in each cylinder, and replace the plugs, it'll fire for about a half a second, and that's it. (yes, a few actual drops)
So with fuel it'll at least fire.
Where should I be looking? I have an idea what I have to do, but I'm just asking for a few opinions before I start pulling things apart.
Based on what I've said... compression good, leakdown good, spark good, fuel going through carbs, and into return line, tank pressurized, will briefly fire if fuel is dropped into cylinder. Where would you start first?
Thanks
-G
Thanks
-G
