dragginblazer
Do Good Jetski Crew
- North Richland Hills, TX
You'll regret the kawi swap down the road. Go with the 144
im in the same boat with my fx1 build. ive decided to go with the 650 pump for now cause of the ease and price which will allow to pay for other mods. also I've heard it has good performance with the r&d pump stuffer and a sxr prop. then later down the road ill probably do the 144.
Sent from my SCH-I510 using Tapatalk 2
The 144 will make more low speed thrust IF the whole inlet is changed. Its a lot of work without previous composite experience. The Kasasaki swap is easier and works about as well with the small FX1 inlet.
see above in red and particularly the part left in blackMore evidence you should go with the Yamaha.
