Zero Client
BeerrroooOOOT!!!
- Douglasville, GA
Hey guys,
I've got a 62T-Y1 717cc cylinder that I don't know whats up or what it was meant for. I took it out of a '94 WaveRaider, but the cylinder's objective has got me stumped. Ive re-built it twice as I just can't get the squish dialed in correctly for my WB1 application. At 0.045" squish and 170psi there were still signs of pre-ignition on the pistons and ADA-head domes with pump gas. I was running a 0.050" base gasket too and it still needed more squish relief.
It's possible this cylinder was re-worked 10~15 years ago. Its also possible many people tried there 'magic' on it as well.
On the outside, its engraved RIVA on the front, and also 0645 on the back side.
Its been re-sleeved, likely by LA Sleeve
The cylinder had been bottom decked 0.010" - likely at the time of re-sleeve.
Its been ported. The port job looks pretty clean. I'm thinking maybe Riva did the port-work.
I have no clue if this Cyl is supposed to be running pump or race gas.
I have no way of accurately measuring the port widths, but heights from the cylinder top are as follows:
Top of Cylinder to:
Exhaust port: 35.75mm
Exhaust port total Height: 33.3mm
Top of Cylinder to:
Intake and Boost ports: 53.3mm
Intake heights: 16mm
Boost port height 22.5mm
My engine builder took one measurement - to the top of the exhaust port - and said I need to ditch this cylinder and get a 61x. He also mentioned that the setup may have been planned originally as a stroker motor. The engine cases are stock 62t no porting.
Thoughts?
Top of Cylinder to:
Top of Cylinder to:
Thoughts?
