- North Carolina
So I just put a set of modded dual 44 carbs in my motor. Im running a r&d manifold, vf3 reeds, ported and decked 760. Ski runs pretty well but I fouled 2 sets of plugs yesterday. Not a lot of full throttle runs. pop off is 20 low jet is 115 high is 132.5. Off idle response is good, 1/2 throttle is good and it pulls hard and fast but it seems like it runs better if I only open the throttle to 3/4 or a touch more. If I pin it it seems to not run as good, but I'm trying to be safe I don't want to lean out the motor , I have ran the screws in but I wasn't sure if I could close the high speed adjusters. I'm at 1/2 turn out now and just want to be sure I'm going the right way. Can some one explain to me why it runs so good at all other throttle positions. I seem to gain more rpms at 3/4 throttle then a full. I am tuning with a tach.
