Ducky
Back in the game!
- Charlotte, NC
Please explain. I do not know what you are referring to how do I check?
I have the Aftermarket 44s. Stock OEM 44s almost always have either straight or curved fuel hose inlets/outlets. The aftermarket 44s have 90 degree block fittings pressed in.
The oem 44s have 3 feed holes for the low speed, and the AM 44s have 4 feed holes. I know there are also differences such as the angle of the throttle plate (determined by what the numbers or letters stamped on the throttle plate) and the adjuster screws also have different thread pitches so 1 turn out on the AM 44s may equal 1.5 turns out on the OEM 44s.
