Yami-Rider
TigerCraft FV-PRO
- Texoma
I have about 1 season on these pistons, the plugs look ok to me, but i dont seem to have any carbon build-up on the pistons, Does it take many hours of run time to get piston wash or ?... I know this has been covered before, but i couldn't find a piston that looked like mine do.
They are very clean, very little color
Left - Rear (little rich?) Right - Front (Just right?)
728cc 61x/62t, Mild port/polish, Stock 38s, B-pipe, X-metal box, Fiber Reeds, 35cc 185psi head, BR8ES plugs, Adjustable RPM CDI.
Stock Dual SBN 38's
135 Main
75 Pilot
44 PSI Pop-off
Rear Carb - 48 PSI Pop-Off - already lowered it to 44psi to match front carb.
Almost 1 turn out - Low speed
1 1/4 turns - High Speed
I also noticed my center linkage between the carbs was a little out of adjustment, rear carb wasnt opening as far as the front carb.
Stock Dual SBN 38's
135 Main
75 Pilot
44 PSI Pop-off
