- Mill Creek
I'll see if deftones will post a pic. We had his sj on my other hauler from north of Seattle to Stockton CA
Sent from my SCH-I545 using Tapatalk
This has the potential to cause a few gawker accidents. Wow look at that ..............BAM.I have about a 6" drop in mine. My truck is lifted so this makes it a little easier to load and don't have to back in the water as far when I launch it
Love the look of the dropped hauler with the lift but do u really not have a problem with road debris. Looking at that location & the lack of flaps seems like the ski would be pelted!
I had to make it a little long to clear my rear tire rack.
If the width is the only thing holding you back from hanging a hitch hauler on your Fiesta, I would re-think your approach.Your Jeep is about the same width of my tiny 2011 Ford Fiesta. I measured my ski would hang over each side by about 10 inches left and right. You ever bump into anything with the same over hang?? That's the one of the reasons I haven't built a hitch hauler yet...
Yeah, I would be seriously worried about that much tongue weight. The fact that the center of mass is a good 2' off of what is likely a pretty wimpy hitch bolted to a thin subframe is a little scary. If the hitch didn't break and the bolts didn't pull through the subframe it would likely bottom out your suspension.Tongue weight actually thinking it through more might be the limiting factor. I don't know if my small hitch is rated for anything over 350lb
Must have been a very cheap hitch. I have used a Rad Dudes hauler on a ford escape with a heavy SXR and gone from CT to Chicago, and X2s from CT to FL with no issues. She may sit alittle lower but not bad.Yeah, terrible idea! Have a freind rip the hitch almost completely off his Freestyle using a hitch hauler. Definitely want to have a truck if you're going to use one. Trailer is a whole lot less stress on the vehicle.
Just saw this. None of the big stores like Home Depot or lowes have them. We get them now from a local yard. But they are not cheap. If you need a set let me know we have them cut here.Hey mark where do you get the Trex 2x4's from? Do the big box stores carry them? Looking to replace the bunks on my home made job.
