- florida
took the sj out to the lake last weekend after it sat for about 3 weeks, well its not running so good, if you start off and gradually pull the throttle off idle it will run just fine as long as you dont go wot until after about 1 minute of riding around, if you go wot right off the bat or shortly after gradually giving it gas it will bog down real bad. i cant figure out what is causeing this to happen? im speculating that it could be a bad fuel pump (its the stock 44 with the carb mounted pump) or maybe the plugs have gone bad? any help would be appreciated trying to fix the problem on the first try so im not wasting money. oh and its a 61x/61x 701 if that helps basically stock except for a adjustable rev limiter from promarine
