Hood Gasket glue.
SuperJETT
none
Super Glue.
Go to a hobby store and get a small bottle of it, actual name is cyanoacrylate, or CA for short. It's like $6 for a small bottle that will do several skis. I like the 10-20 second set stuff but you can get slower or faster set times.
SuperJETT said:
Super Glue.
Excellent!!! I have a huge bottle at home.
Thanks.
-o
romack991
homebrewed
Warsaw, IN
freestylegeek said:
I just used the backing that came on my seal material from McMaster Carr. The stuff sticks great!
Are you using an OEM seal, or an aftermarket?
do you know what kind you used and how is it working for you?
thanks
beachedflunkey
wavejunkies
Virginia Beach
I'm planning on using the 3m weather stripping adhesive on my new oem seal. Do you need to weigh down the seal with an unlatched hood as it bonds (assuming no goop sticks is leaking around the edges) or just kind of smush it in place? Also, I still had some bits and pieces of old glue around the lip when I repainted - should I scuff this up a little bit or will it be fine?
RoyalFlush@PCB
Shootin' The Crap
PCB
Excellent timing on this topic---my hood seal needs to be re-glued.
AFTER I replace a broken steering cable. :banghead:
Prem1x
Tinkering obsessed
Austin, TX
The 3M Weatherstripping in black can be had at auto stores like Autozone.
I've gotten decent sized bottles of Super Glue (cyanoacrylate) from Target.
2lick
Brap!!!
Limerick, PA
Man this is what Ilove about this site. I was just sitting in class thinking " when i get back to my appt I need to ask how to reglue down my hood seal" I used liquid nail and that worked about as good as spit lol. Thanks guys for making such a great site.
Thanks-NICK
ski4
gonzo
cleveland
shoot same boat here, need to do mine this week or so and also was thinking about using contact cement, seem like it should hold
hell it holds that damn turf in place pretty well
