john zigler
Vendor Account
- wisconsin
Placing order for watcon now. Thanks
Also, what are you guys doing with the sag in the glass near where the handpole mounts? I was thinking I'd level it out with some epoxy
Sent from my SM-G900P using Tapatalk
The known SN SJ hull sag is a big issue, and can affect the hood seal actually sealing. Lock your pole in the up position, and look how much you can "flex" the front engine compartment by pulling on the pole. Just filling with epoxy is really not enough.
On SN's I have built, I re-inforce the front area with a small piece of angle under running full width, and a flat plate on top in the seal channel. Through bolted. This will straighten, and stiffen it up.
John
