JetManiac's Hood Parts Shop
Ratcheting Hood Strap Kit
Ratcheting hood strap kit $49.95 sale 43.95
-replaces stock latch or extra security and use with stock hood latch
-includes complete SS mounting hardware(bolts, washers, and nylock nuts) for both ratchet and straps.
These 1" ratchets are made of Type 304 Stainless Steel for marine and high moisture applications.
Break Strength: 1,760 lbs
Work Load Limit: 586 lbs
Straps are
Black Polyester Webbing with Web Tensile Strength of 4500 Lbs
*blue, red, and green thin lightweight straps also available
Blowsion standard hood strap kit $44.95
-good for secondary protection with hood latch setup or as backup with ratcheting kit in extreme use. Uses plastic buckle clips to close.
Hood Hooks
Hood side hood hooks (prongs)
RRP billet hood side hooks/prongs 79.90/pr
New OEM RN SJ hood side hood hook/prong 23.90/ea
(Add SS mounting hardware 5.)
Cold Fusion billet hood side hooks/prongs 79.95/pair
ADA billet SXR hood hooks 69.95/pr
Hull side hood hooks
ADA hull side billet SJ hood hooks 54.95
RRP Rickter hull side billet hood hooks 59./pr.
Cold Fusion FX1 front hood hook 49.95
Hood Latches
OEM Yamaha SJ recon, used hull side hood latch with hardware 44.90
OEM Yamaha SJ New hood side latch receptacle with ss hardware 24.99
(Fit all years Yamaha SuperJet 1990-2020)
OEM Yamaha Waveblaster recon, used hull side hood latch with hardware 39.90
RRP billet adjustable hood latch piece $75.95
Replaces the top latch piece on Yamaha SJ latch (Black, red, or blue)
RRP complete new adjustable hood latch assembly 224.95
(adjustable hull side latch with hood side receiver)
Thrust billet adjustable hood latch 74.99
Limiting rope kit $45.90 sale 41.90
includes:
- Stainless tray loop mount
- Stainless allen hardware with washers and nylock nuts
- Carabiners - 2 high quality stainless marine
- Stainless limiting rope pole mount to bottom of pole steering stop
- Sta-Set rope kit with elastic keeper and clip to pole base area
(High strength Sta-Set marine rope, polyester double braid with high strength, low stretch, and extremely durable, yet it still remains soft over time)
- Kit is designed to be strong but also super light, total kit weight is only 5 ounces
Limiting rope handlepole stainless mount $10.95
* mounts to underside of steering stop on pole
Stainless marine grade limit rope carabiner 9.90
Hood Seals
Watcon replacement hood seal 39.95
(Fits all SJ, Blaster, B2, FX1, Octane, SXR, and many other skis)
Yamaha
OEM RN SuperJet Hood Seal 192.99 sale 154.90
(fits all RN Superjets 1996-2020)
RRP Rickter hood seal 54.95
Secondary hood seal for Rickter hulls 37.95
