Super Jet hooker 9/15 or 10/16?
I emailed impros and didn't get a response. Just wondering what hooker you guys would recommend me getting.
I have:
freestyle ported 701
ada head running about 170 compression (not sure what dome size)
b pipe
stock 38's? (not sure)
Thanks
Waternut
Customizing addict
Macon, GA
I'd go 9/15. I ran a 9/15 first with a 61x/61x motor with total loss, b pipe, and 175psi and it was good. Then I ran a big bore ported motor at 771cc running straight av gas at 210psi with dual 44 GRS carbs, total loss, and b pipe and it was still good.
GIL
Power In The Hands Of Few
Cullman AL
I have both and can't tell any diff between the two without a tach. I have run them behind my 5mil Jetworks Lamey. The 10/16 is in the pump now and for no good reason other than it was the last one in the pump.
ps-the Hookers are the ONLY way to go if your not gonna pony up and buy a MAG pump! (and I can't make myself buy a MAG because the Hooker does sooooooooo good!)
I would love to buy a mag but I dont have that kind of cash right now. My current impeller is starting to cavitate so I was gonna try a hooker in it but wasn't sure which pitch to go with.
Schmidty721
someone turf my rails
WI
Have you tried any Big Hub Skats, Gil? Art suggested the Skat over Hooker on my 5mm setup.
Murdock
'03 SJ
Houston
I ride a limited 701 and am considering the 9/15, but I like to chase cruisers on Lake Travis. How much mid/top end do you loose going to the 9/15? Should I consider the 10/16 if I want more than just bottom end? Thanks for any input.
Tanman
Jus' keep er' pinned
Ketchikan Alaska
9/15 Hooker!!! I love mine in a limited 717 set up :brap:
my superjet is still plenty fast for me but gained some deffinate hook up and pull on the bottom. You won't be dissappointed
tor*p*do
Squarenose FTW
NW NC
I was told 10/16 in a modified ski by Dave@ impros
I ran mine in a ported, piped, hi comp, MSD enhancer 61x and it worked great
I then blew my motor and put in my old motor: 650 w/pipe, 185 psi, etc
and it STILL ran great!
Aircraftsalz
Thrust built Dasa Power
Off site
I'm running a 9/15 Hooker in my surf ski, 61X/61X B pipe 180 comp, MSD Enh.. Decent bottom end, great Mid & still fast on top... Works great in the surf, I say go with a 9/15.
Don 79 TA
Still Fat....
you know this really comes down to trial and error and personal taste
to me, i liked the "pop" the -15 gave
i didn't care to much for the -16, but again personal taste
i myself felt a difference between them, especially coming out of a deep sub
i don't think you can go wrong with either one, and Dave is usually good at repitching if you need to or want to
I also felt the ski more stronger in the mid and upper with the -16, not exactly where i wanted it
the -15 had more low end pop over the custom 13-15 solas Dave setup for me
i can probably break the -15 loose with my current setup if i whack the throttle wide open, but then again i am running well over 200 psi on a 5mil
i've tried many props/pitches/cut backs to set it up the way i like it, and right now an out of the box -15 is pretty hard to beat.
also keep in mind, i am WELL over the 200# range, probably closer to 3+ with gear on, so it works for me
I enjoy my 10/16 hooker. Nice snap but I did notice a drop in the mid range "push" vs my cut back 13/18 skat. I'm going to try a larger exit nozzle and see if that gets the push back. - 760 ported, 180psi, stock pump w/ blowsion cone - BOB hull -
All in all I would recommend..
I just bought the 144 Solas 12 van mag and I want to have all bottom end. I have a waveblaster 1. 701 b pipe. Looking to build a new pump all together and need to know what prop , pitch, make. And any info or advice would really help. Thanks.
Every boat is so different there is no such thing as a majic prop that works for everyone although i feel the hooker 9/15 is dam close, recently tested both on my full limited sj, I do have mag pump which may change loading compared to stock the 10/16 was just to much and wouldn't let me get into high rpms so it actually slowed me down, tried a smaller cone with it that helped it unload but had cavatation issues, 9/15 opend up throttle range and curve and stays planted, I run mid 50's mph at 5,000ft which I would think put me in 60's at sea level and still has that arm jerking feel out of the whole. I don't know to many around here with 144 pumps that don't have 9/15's.
