Hooker prop??
Bishop CA
I am getting the skis back out from their winter storage (I guess you could call that a winter). I'm doing some reading up on props and keep seeing Hooker props come up as a good option. What is different about these compared to a Solas or a Skat? Are they a million dollars? Has anyone rode with a several different props including the hooker? How was it? Any other ideas?
Bishop CA
How do you think that would run in my ski? It has a 61X motor with a wetjet pipe, Westcoast head, 46mm SBN carb, Oceanpro FA, TDR waterbox and a little port work. I'm at 4000' above sea level. How much are you selling your prop for?
BruceSki
Formerly Motoman25
Long Island
My buddy is running a 61x with b pipe and Ada head and the 9/15 works great.
On my dual carb 701 it wasn't enough prop. But I run my pipe real dry and also run 33cc domes. That little more oomph was enough to make me jump the fence from 9/15 to 10/16.
My prop was just re-welded back to a fresh 144 4 rides ago so it's as good as new. Looking for 220 shipped.
I think the 9/15 is better suited for flatwater. And the altitude change would probably make the 9/15 more suited as well.
Bishop CA
Do you happen to have a picture of your prop? I'm thinking it might be a good choice. I'm sure it will be at least a little better than the stocker.
BruceSki
Formerly Motoman25
Long Island
Better than a stock 08'-up prop? Yes slightly.
Better than a 96'-07' prop?. Wayyyyy better.
BruceSki
Formerly Motoman25
Long Island
If you have an oem aluminum prop in your ski now, you will find gains everywhere. Going to big hub stainless swirl prop is a big upgrade over the old crappy aluminum props.
No way you will be slower than 40mph.
Bishop CA
This is the only prop I have on hand now but I'm sure it is too much prop and my ski will bog and be a pig.
Bishop CA
The one in the box is a brand new prop that has never been installed. The one that's in my ski appears to be a stainless unit but is OEM with the hex exposed on the outside.
