FlightPlanDan
Don'tTrustAfartAfter50
- Crescent Beach, FL
Check for an air leak by running the ski on the hose, spray carb cleaner around all of the gasket seals while it's running.
When you hit the spot with the leak, depending on where it is, the motor will either bog down or rev up.
(this is just an easier "get started" way than pressure testing)
If it will idle.
If it will idle.
