- Ocala, FL
Working on the 140mm pump swap in my FX1 and i need to remove the kawi coupler off the zxi drive shaft and my yami coupler off my fx midshaft preferably without damaging either shaft.
What can i use to hold the shaft without damaging it? My fx1 driveshaft has all sorts of markings on it from where someone used a vice or something to hold it to put the prop on and id like to avoid that damage to my new shaft. Ive heard heat helps alot when getting the coupler off but i still need a way to hold the shaft. Also they are normal threads correct?
