Your best bet is to do some research on here because the numbers alone don't mean squat since the hub diameter and shape of the blades also plays a big role in how the prop performs. A 13/18 swirl will be similar in performance to a 9/15 hooker for example. Your best bet is to start a search on the word "hooker" and start looking at what prop people are happy with on what engine/ski setup.
and dont forget that when you finally buy a prop it probably wont be the exact pitch it says. I got a C75 Skat 15/20 swirl and it was actually 17.5/21. Root pitch is a big determining factor aswell. Trial and error is the way to go. Doesn't hurt to collect as much data as possible. But remember just because someone bought a 9/15 and it was great doesn't mean your 9/15 will be the exact pitch as theres as many props are off.
