UneducatedFX1
X-H2O
- Canada
This was definitely not caused by water. The only thing that I did was replace the return line and it is back to normal. I have since done bigger stabs, subs, and falls and have no problem with water through the motor.
Now that I think about it, it was a little sluggish overall, probably from vapors. It is due for a carb rebuild, and when I say it is running great or normal, I just mean for this particular ski. I still don't quite understand why it would make it run completely terrible, similar to sucking in water, for the first bit. I'm still thinking that check valves in the pump aren't quite sealing and it is letting fuel drain back with a break in the return line.
I had a simular sort of issue with my Fx1 i was doing tricks fell of and when it started it kept wanting to die, pulled the carb today as we couldn't even get it to start, turns out the pulse pump is was weak and one the floats that pushes fuel through (those round disc like things that suck and push fuel) was bent out of shape and was broken so i've just order a rebuild kit, might solve your sluggish problems maybe, (sorry if this isn't helpful)
Dale
