- Coeur d'Alene Idaho
What kind of the top speeds are y’all seeing and what setup are you running? Currently the Yamasaki is running about 47 with a stock 62t 701 and a 10/16 hooker in my 140 pump.
43.6 mph - 440 Harry Klemm 92 Octane Hammer kit, JD intake grate, stock ride plate mod according to Cliff Jones
Changing to a 701 engine in a Kawasaki 440/550 is not worth the effort.
Is that 140 pump a good upgrade? Did you run it with a 550 pump before or just the 750 pump? I have a 701 in my js550 with a 19* prop it runs great but I have debated the 750 pump swap.What kind of the top speeds are y’all seeing and what setup are you running? Currently the Yamasaki is running about 47 with a stock 62t 701 and a 10/16 hooker in my 140 pump.
Per the Rhaas website under needed parts, "Kawasaki 750-800 pump (750zxi pump cannot be used)"Curious, will any 750 pump work even from a sit down? Or does it have to be from a standup?
I tried a 20” prop in a 550sx pump that worked for another member but the Yamaha just spun itIs that 140 pump a good upgrade? Did you run it with a 550 pump before or just the 750 pump? I have a 701 in my js550 with a 19* prop it runs great but I have debated the 750 pump swap.
https://instagram.com/p/CLASjWSA96g/ Vid clip here of radar run. This was with a "Freestyle pitch" on the prop. I've been wanting to up pitch and see if it will break 60.
Well that was the next question I was going to ask. Sexpanther and 1970Camaro and fastgtfailane et al, assuming I would convert my 550sx pump to a 750 pump, would you recommend a Kawasaki 750 engine swap or a Yamaha 701 62t or 61x engine swap?
