- Redding, CT
1) How many bypass holes on a SBN38?
I am rebuilding some very corroded carbs on a stock Yamaha '98 dual carb superjet (SBN38's). I only see 2 bypass holes (plus the outlet on the engine side of the butterfly) but the corrosion could be hiding some. I would like to confirm there are only 2 and I am not missing 1 or 2. I did a search here and google and no one says how many there are.
2) What is pop-off pressure for a dual carb '98 w/ SBN 38's?
I am measuring about 50 - 55 psi, seems high. I have seen the chart that says "superjet 38-42" but I know there are 1 and 2 carb versions of SJ's with different size carbs, so I would be surprised its one setting for all Superjets.
Thanks in advance.
Thanks in advance.
