How much compression, DASA 1100 (10mm 94mm) - 46cc domes
Christian_83
Xscream
Denmark
Hi Guys
So how much compression are you guys getting on a DASA 10mm stroker on 94mm pistons, with 46cc domes. fresh build. 1.50mm squish.
I’m getting 225psi, which I think it’s pretty high for pump gas domes :oops::rolleyes:278909431_10161661034419992_6699291520975754848_n.jpeg
DylanS
Gorilla Smasher
Lebanon Pa
Thank god you posted this here too I was scared the Facebook scientists were going to claim another victim
No fluid in cyls?
Did you check squish clearance?
I’m assuming you used a dasa base gasket so squish clearance shouldn’t be a issue but those numbers seem stupid high on 46 cc domes
Christian_83
Xscream
Denmark
I had a small shot of oil in each hole.
Yes squish is 1.50mm wich should be close to perfect.
Yes DASA base gasket. i will fire it up tomorrow and see if it settle a bit.
