How the H*ll do you keep UMI steering Tight?
My kit came with THREE O-rings (large, small, and VERY small, like 3/4"
in diameter). I'm not sure where that third small one is supposed to go.
The instructions and diagram do not show or mention this O-ring.
Anyone know?
Just throw it in the tool box the bearings will get water in them even if you use new o rings and a ton of grease. I can't wait till mine takes a dump so I have to switch back to stock.
vitaly
Анархия - мать порядка!
NY/NJ
crush the top of the nut in a vise works every time !~!! I have 3 running crushed nuts and NEVER had one come loose !! Simple, cheap, non threating, cake to adjust.. What could be easyer ?
if you drill a hole in your shaft you will need a few holes in the nut unless 1/2 turns work for you and fight a cotter pin.. !
What he said.... x2...
stanton
High on jetskis.
atascadero,ca
[outdated]i just bent the nut in the vice, only smashed -.005" and wouldnt reccomend any more.
stupidly overlooked, i dont understand why companies flake out on the little stuff.[/outdated]
doesnt work
jetskee
Team Not-As-Ugly-Anymore
Newark, Ohio
It is not a spare, it is a completely different size than the other two, so I
assume it belongs in there SOMEWHERE.
waxhead
wannabe backflipper
gold coast
get two nyloc nuts
put them in the vise
cut of the nylon part
you know have to slim nuts
you can tighten one and use the other as a loc nut
job is done and issue is gone
vitaly
NY/NJ
get two nyloc nuts
You don't need the nyloc nuts for that, any two nuts will work as long as they are thin enough to feet the exposed bolt thread.
The lock nut is like the most dependable solution short of welding...
waxhead
wannabe backflipper
gold coast
you dont need to use nylocs of course
but they are aleady nice and thin when you cut the nylocc off
its just an easy way to do it
keefer
T1
Tennessee
That sounds like the best solution to me Wax. Currently I have the original nut with Red Loctite. The first time it gets loose I will go with the Wax solution.:biggthumpup:
