how to 750 pump into an x2
ill have a look and see if i can find anymore pics for you , they are on my other computer so ill have a look lata when i get home.
it isnt that hard to shape the shoe tho just bolt the pump in frist and shape the shoe so it fits nicely up to the pump and hull.
butti
lone wolf
F-XTC
i used a 750 pump in my fx-1.i dont use the rubber gasket.i just silicone that area when i install the pump.
fl keys
im just about finished putting the 750 pump in my x2. will get some pics soon. I cut the front off the 650 pump and used it for the shoe. I hat to weld some plaet to the sides to have something to glue too. then made a intake from scratch as i did not have one. not that big a deal just time so far im in it $0
dfw
Did you bore out the stock x2 nozzle
Im using an old aftermarket 84mm nozzle. I would advise against using a 750 pump because making the shoe fit is a lot of work for no performance gain. I did modify a 750 impeller and slotted the mounting holes on the 650 pump aft 5mm to get the spacing correct.
