- Mammoth Lakes CA
I may be upgrading my 44s to 46s. Wondering if I should start off with the same jetting, or go bigger.
Yeah that's a good thread I'm subscribed to. I hadn't checked it in a while and forgot it had larger motors tooJetting will not be the same, not sure on your setup but check the carb database thread for a similar setup to get you started
http://www.x-h2o.com/index.php?threads/carburetor-specs-database-superjet-and-blaster-1.19403/
Hurricane with 144 solas mag, 10/16 hookerWhat pump/ hull are you runnin?
