- Valdosta GA
This thread will be long. At the same time it's long overdue but Mr. Carter B himself asked me to post my build. Before I begin...a big thank you to my wife Leslie, the Lake Powell crew(James, Jeremy, and Eric) and Carter himself.
I had NO knowledge of building skis before this. I had never worked with fiberglass. That changed drastically...so let's go...
My blaster in 2014 was a stock blurple 701 with a pipe. In 2015 it was a 1200cc 65u swap with a stock tunnel and some prop. At the end of 2015 I decided to whip up that work and build MY dream ski. I spent 2016 doing just that...
Stock and tired in 2014
At this point I'll fastforward through building a 1200. It's pretty damn easy. Let's jump to the destruction. Family always helps here...
So I have built some cars and I like to start from a blank canvas! The blaster was stripped COMPLETELY. Every rivet, every fastner, everything! was removed. And then it was time to cut! Carter sends templates. Use them. So it begins...The first cut
The nose:
I don't have a picture of the just the tails cut off but if you use the templates...it's pretty self explantory.
No be reminded...I have NO fiberglass skills at this time. I have never mixed resin at all. So I experimented a little and decided to make my first piece to block off the old exhaust hole...let the fun begin...
While we are discussing fiberglass. I mainly used 12oz biax everywhere. I used a little 6oz for finish work. I started with west systems epoxy but ultimately ended up with jamestown products. Their resin and fairing compound is EXTREMELY easy to work with and price friendly. I will not dare to tell you how to work with the fiber glass. That comes with time, humidity, angles, etc. Just jump in! The good thing with fiberglass is that anything can be repaired.
With that said...it's time to fiberglass....
The nose:
