Ok Well I had to change my motor mounts so I wanted to block the Crank case drain off too. Well lets gets Started
1st get the Ski to a good place to work on it and make sure to have light. Then Remove the battery from the ski to have extra room and to prevent any problems down the line.
Now That is done next disconnect wires from your E Box. The Starter and stator wires.
Also dont forget to dissconnect your carb or cables at the carb. I just removed the carb and set it to the side with the cables connect to it, some goes with the fuel lines. I did dissconnect the pulse line.
Now that is done, I removed the exhaust at the clamp. Then unbolt the engine. (on a side note these mounts are the good ones I have installed)
Then lift the engine out of the ski and place it on the ground or your work bench.
Now that part is done. Next step is to Loose the cable at the Exhaust
Then you can tilt the engine on the side and then unbolt the drian
Then you have this part that well falls off when you remove the 2 bolts. Place it off to the side. It is no longer needed.
OK Now time for the plate. I got my plate from ExtreemThrottle. I think the plate is great and the price was great too. Dave is a great guy to deal with. If you need one I would order it from him. One hes a great guy to deal with. 2nd he has the best prices around too. Fast shipper also
Now make sure you have the holes where the plate mounts
