Want to Buy HPE motor
I have everything to build what you want. 61x cases, 62t cases, 61x cylinder ready for port work or just bore and run, new oem pistons, good crankshaft. Can give everything to paul lehr and he could port and build it if you want the cylinder worked on.
Roseand
The Weaponizer
Wisconsin
Looking for under 10mil stroke.
If anybody has an hpe 800 5mil, php 4mil or stock stroke big bore that'd be ideal but still interested in a billet Cyl motor.
Roseand
The Weaponizer
Wisconsin
Thanks guys, have an HPE in the works but it won't be available until October. If anyone has a 760 based 5mil HPE build available sooner I'd still be interested.
I've got an HPE 5mil with the lighter full circle ADR crank. Built new in 2017, ran a few tanks of gas thru it and never got it tuned in or running right and pulled it. It's been sitting on the bench since. OEM 454 carbs with V-Force 2's, port matched exhaust, stage 3 porting, etc....a few pics below before the carbs and exhaust manifold added. PM me if you are interested.
ADR 5mil long rod crank (lightweight full circle 5 mil longrod crank - 2 lbs lighter than the usual 5 mil crank.
Trench for 5mil
HPE baseplate
Crankseals
Bore cyl
2 prox piston kits
Port cyl Stage 1
States 2
Stage 3
2 HPE stroker domes for ADA heads
Ada headshell
Ada girdle studs
HPE allen girdle kit
Jetting ( 117.5 low, 122.5 main, 1.5 needle and seat (stock) and 65g spring. Pop off is set to 30 psi.)
Ported exhaust manifold
Bore is 84.5. - engine size is 819cc
vforce 2s
