James Findling
two stroke madness
- Denver, NC
Set up as is.
'01 Superjet
Riva
Riva Dual Powerbombs with dual pulse lines with Fly flame arrestors
Riva Dry Pipe
Riva Girdled Head @ 175 psi @ 81mm @ 35cc domes
Riva Groovy Ride plate
Riva Intake grate
Riva Rear mini Sponsons
My buddy was riding this ski harder than I would've. I'll add pics but it looks like detonation from too-hot cylinder walls. (He was riding like 2-3 miles flat out, I was worried but couldn't keep up without running my ski hot.) Pistons and cylinders are toast. They were 175ish each. (Sounds tired) Now the front is 40 psi and the rear 160 psi roughly. The plan is I have a HPE cylinder to swap, ported out stage 2 matched up with ProX 82mm pistons without a boost hole. The plan is to sell the Riva girdled head and domes, sell the Riva dry pipe. Swap to a new ADA girdled head and new Factory Limited Pipe. Most likely add MSD Enhancer and Lightened Flywheel. Before I do I was curious about running dual Powerbombs on this setup. (It's overkill right.) Any baseline specs for these carbs? I am not very carb friendly. Also what domes to run? It's hard to trust ADA when they sent me "35cc" domes that took my '09 SJ from 170psi stock to 215psi.
Any help or advice would be appreciated.
'01 Superjet
Riva
Riva Dry Pipe
Riva Intake grate
