this...project...sucks...errr. must think positive... end result. can't wait to get the bottom done... once the mold is done and i can flip it over, i am confident the top will go a LOT faster.
there is a STUPID amount of sanding in a project like this. when you think your done with a phase... your not. a lot of 1 step forwards, 3 back.
nothing special to report - more sanding of the primer. i had to lay down a few more coats which I did last weekend. once dried, sand down with 80 grit to remove the light texture/orange peel.
after 80 grit, then 150, 220, 400, 800, 1000 then polishing / waxing. the problem when going up to a higher grade, the sand paper clogs after only a few passes.
sanding paper/block in one hand, air fitting in another hand to blow off the paper... sucks, time consuming but the only way. once i hit 800, i will switch over to wet sanding rather then dry.
between grit changes, used some cheap $1 spray primer in a can as a "guide coat". this way i know what has already been sanding and can see scratches removed from the previous grit.
as long as a do a grit-a-night this week, mold making time this weekend. i came down with the flu a week back which put me out of commission for a little while.
