- Cleveland Ohio
Well, not really, the hull is still bulletproof and water tight....but I run it up on rocks and the beach and leave it laying on the cement ramps and slam it into the ground in 2 feet of water from 10 feet up....:smokin:
The bottom is lookin pretty gnarly....How long before I wear through the hull or make it weak? Do I need to put some layers of glass on the bottom this winter, or just keep runnin it... Any maintenance I can do to it? Put a layer of carbon on the bottom where the gel coat is gone?
Hull builders???
Hull builders???
