FJXP
I wish I had a million $
- Toronto, Canada
Is the strength any different from a regular comp hull ?
You probably want to ask your local Rickter dealer. Supposedly that stuff is stronger, so they use less of it.Is the strength any different from a regular comp hull ?
All my cloth an reins are military grade
Will you have a ski at WF for test rides?No they want the highest quality the apache helicopter has a lot of carbon in it
We have a 16 XFS Comp w/ the Textreme hull and it's been flopped many times learning to do flips. It's a very solid hull, not some flimsy "race only" type of construction. Other than the weight savings and the cool factor of the Textream, the Comp model also has a larger intake tract and no foam.
Have you talked to Taylor at TC Freeride?
805-225-1515 taylorcurtis4@hotmail.com
Hull I haven't got yet .. I have a few options and I'm asking hull questions to see witch option I should take.
Yes trim and it's a 148 mag pump
Isn't there a dealer in Canada?
You would think so .. But nope ... I wish !
