Yup, be sure you are on the AC setting of at least 100 volts range. Also sometimes the RFI from the high voltage can freak out a digital meter. Use an old analog swing meter if you have access to one. Take the plugs out and ground the spark plug wires to defeat the high voltage, this might make the reading more consistent.
