Yami-Rider
TigerCraft FV-PRO
- Texoma
Good eye, those are tiny fuel filters, I'd change over to the bigger round paper style most people run $6. Also never seen a/m carbs mounted in that orientation, idk if that would matter. It be cleaner mounted the other way, so you could mount the hoses to side wall. Also I wouldn't run that cheap colored hose, its known to leak, causes issues. Switch over to the OEM style hose from jetmaniac.
This is the fuel line and filter I would switch too. Best to fix everything right, so your not fighting multiple issues.
Cool, php should be able to handle it
