I just found out my local booze store sells race gas 98 through 118 octane. Could I take the 118 and mix it with 93 and be good? It was about $100 for 5 gallons of sunoco 118
I just went thru this… . Each of the fuels ABOVE the SS 100 unleaded have different stoichiometric fuel ratios and slightly different specific gravity’s and can require jetting/mixture changes…
Stoichiometric fuel ratios are as follows
Pump gas with 10% ethanol is around 14.1
Didn’t look up pump with 0 ethanol
SS 100 unleaded is around 14.2
110 is around 14.9
112 is 15.1
I mistakenly bought the 112, thought I was pumping 110…. then went for a Sunday ride and brought some along to add when I was getting low…. Well my ski ran like poop….down 50% on power and won’t rev out. Then i wondered if it could be the fuel… looked up the stoichiometric ratio and specific gravity and found it different than the pump gas my ski I used when I tuned my ski…. Switched back to pump gas and resolved the issue… called Sunoco tech and confirmed my findings…
The SS 100 unleaded is the closest stoichiometric ratio to pump gas. If you already tuned your ski mixing the SS100 would require almost no tune changes..
When I added the 112 I was roughly 50/50 race and pump.. or 60/40 race/pump and it ran like crap as far as power goes…
If you get anything other than the SS 100 unleaded.. retune your ski to your new fuel mix…
My ski is a Lamey 8 mil stoker on 200 psi, Msd enhancer, RRP pipe, 148 pump 23 deg timing…I run 91 pump gas in it, it’s a surf rec boat. I don’t hold it pinned, usually cruise 30 mph max, sometimes I’ll take it up to 40 mph briefly… I should be running higher octane as well… you should too, especially since you have a lay down pipe and Msd total loss..
SS 100 and pump 93 mixed 50/50 would be around 96.5 ?
The higher the Stoichiometric ratio the leaner the tune needs to be….
Since you have Msd T/L…. I’d pull the back cover off the brain and get your dip switch positions and plot your timing curve next… that’s critical to know
Fuel Selector | Sunoco Race Fuels
www.sunocoracefuels.com
