- Forsyth County, GA
As it states I want to bump the compression on my ski but I have read all of the horror stories of cracked cylinders so I have a few question.
1. At what point is a girdled head necessary vs. a stock milled head for let's say 180 psi or leas? I am installing my b pipe tonight so I've read a lot that compression plus pipe can lead to a cracked cylinder? Thoughts?
2. At what point does dual cooling come into play? I ride in the southeast and water temps in the summer vary between high 70's to 90's depending on the time of the year. Would dual cooling be necessary or recommended once compression is bumped or will the stock cooling be sufficient?
Also when adding dual cooling where is a common place to add the second npt? Do most use the extra raised port on the side accross from the stock fitting and drill all the way through, or do they drill and tap the pump housing directly?
