that sounds about right!! kawi claims 351 dry!!! ad a 20pound battery an thats 370!!
Seems they all gain weight once they leave the show room floor. I would love to check a new ski SJ or SXR and test thier dry weight claims.
drain plugs and foam channels to let water out? do a write up when you refoam with polystyrne
Grind half the hull away, and reinforce with Carbon :biggrin:
Is fuel about 7Lbs per gallon?
The bottom of the hull is 5/8 thick. I thought that was crazy.thats what im thinking of doing!!! the hull is so thick!!!
