I wonder whats under the hood
That Spencer kid does them with very little effort. Very talented. This world finals outcome will be very interesting. I have never seen Stoyer complete a flat-water backy. I thought Jason has been on Wammers hulls(watercraft factory?) for the last couple of years? not stock.
No Nick, But Next year I'll do both comps(Havasu and Pismo). This year, just like the nationals(weak), we just couldn't get enough practice time in. You better represent in the waves!!!!!!!!!!!!!
Y
yamaslut
Guest
my ********ing boss shut me down.... no pismo for me now..
I'm gonna go kill myself now:shooter3:
custom rider
We make you fly!!!
Denmark
you tube video. It looks like a carbon xft hull. the motor is rippin anyone know whats in there?
http://www.youtube.com/watch?v=my_58dljjLw
Hello
I know whats in that hull because I build the engine for my new XFT hull.
On the movie I used total loss but tog it off.
It is a very fast ski and sometime it is too fast for hood triks.:firedevil:
If you need more info just email me..
The engine:
Factory B pipe
ADA head
PV Lamey 8mm. 85,5mm. bore
48mm. carbs
Vforce reeds
MSD enhancer
Riva flywheel
144mm. OEM pump with TBM pumpcone and 12/19 Skat-trak impeller.
Thanks.
Bo
Denmark
freestylegeek
waiting...
Grand Rapids, MI
Hello
The engine:
Factory B pipe
ADA head
48mm. carbs
Vforce reeds
MSD enhancer
Riva flywheel
Thanks.
Bo
Denmark
e-mail sent on how you can get an enhancer to work with an 8mm stroker.
custom rider
We make you fly!!!
Denmark
Hello Matt
I send a mail in your Box
You are right about the timing on the enhancer but the advance is only
23deg. 3-5deg.retard at 7000rpm thats is only 18-19deg. advance.
I am now using 28cc domes that is 170psi with power valve open. I have try
with 26cc that is 200psi with PV open it made a huge difference. in power
I always use 98 octan gas.
I put on the Riva Flywheel and MSD enhancer for som testing and I was
surprised because the ski still had a very perfekt hit.
I use the ski as a demo ski for customer and people are sometimes very
hard on the engine but it still run perfekt after 6 month.
The reason this ski runs so good is because all the parts runs good togher
and everything is adjust 112% right.
Just put the enhancer and flywheel on your engine I know you will be happy.
If you need more help just mail me.
Venlig hilsen / Best regards
Bo
Customski
Saksen 8
DK-8464 Galten
P.: +45 40 724 888
CVR: 29430993
www.customski.dk
