Stupid ass piece of poop idea of mine taking the damn flapper off.
How did test ride go?
Went perfect. Runs perfect with the Scupper Flap back on it......... Been chasing my damn tail for almost 2 months now!!!!!!!!!!!!!! It all started when my pipe was running to hot, pulled to the bank, popped the hood and the pipe was steaming hot........ Worked on it, got the temps back to where they need to be, but in doing so, would pull to shore to check, and small amount of Smoke would be in the hull.............. Then kept chasing my tail....... Everytime I would "Check" there would be smoke".......... Pull Pipe, Reinstall, Then pulled motor, reinstall, test ride, pull water box.................................. on an on................ Just the damn scupper flap....... That said, I do not see how the Thrust setup does not let in exhaust smoke at low RPM's...... Is the ball a whole lot lighter than the Versa Max ball? Allowing it to get sucked in place?How did test ride go?
Well, if I was starving for air, wouldn't the ball be getting sucked into a closed position????????
I think it's been said but...The smoke only travels up the scupper tube because your starving for air.
You are running an Xmetal pole with their tubes, they are a good bit smaller than the RRP tubes!!!!!!Maybe starving was the wrong word. Motor is gonna pull air though the path of least resistance. Mine is just an 865cc with 44s. It needs more than pole tubes.
I can only talk about my Edge, Your freak has so many places it is sucking air from you are ok!!!!!!!!!!!!!!! LMAOJust to confuse the matter further....I have been running an original versaplug max with no flapper on my Superfreak Badass since 2012 with no exhaust sucking issues. I also switched to a rrp pole from an xmetal at some point and completely closed off my hood breathers with no performance loss at all and I run a 967 with dual 46's.
