Identifying the steering cable in my 2013 Rickter FS2
Trying to identify the steering cable in my 2013 FS2. The sheath is Gray with no markings and it's 7.5" longer than a pre 08 superjet cable. I didn't build the ski so I'm not sure what's in there. I tried a pre 08 cable and it just BARELY reached so I'm not sure I'll run it as it may tension when the pole is moved. I'm running full length pole tubes and rickter steering/ steer stop. Any ideas of what cable I might have? Thanks
After checking every sbt yamaha cable length it appears I've got some sort of sit down cable(only ones that are ribbed grey) in there approximately
127.75" long (one end is broken off and It piled up so I cant measure exactly) only cables I can find that's close is a 90-93 650 SJ measuring at 123.75". I've read every yamaha cable description and can't find anything even close to 127. Everything on sbt is either 90", 123" or 140" ish. I fitted a pre 08 SJ cable and it's BARELY long enough to mount with full length tubes, I'm leaning towards the 90-93 650 SJ cable that's 2.5" longer. can anyone confirm if these 650 cables have been used in the fs2 hulls? Thanks
long beach local
long beach local
Az
That looks like the very long grey Blowsion cable I have in my Freak. It’s about 15”longer than it needs to be snakes around because it’s to long but it still works good after 7-8 years of salt use. I don’t know how long it is just it’s grey and from Blowsion and wasn’t cheap.
I’m using the ew2-61481-00-00 square nose cable in my FS1. It’s long enough with full length pole tubes and just as important it’s got 4 inches of throw.
That looks like the custom cables I have made at cali push pull. At least 15 people have gotten the cable I designed from him. It should be 3 inches longer than a standard sj cable and have .375 inches more throw built into the cable if so. To allow 3 rebuilds of the cable, and to never allow the cable to actually bottom out and see stress.
Sent from my SM-G970U using Tapatalk
