SX/SXi/SXi Pro Impeller removal
I am wondering if there is some way to remove an impeller without an impeller tool? Ski is completely torn down so I have the drive shaft out, is it possible to use this in place of the tool?
Get the proper tool for the job. Inexpensive and it could potentially save you future problems. You don't want to accidentally bend the shaft or bung up the splined end of the shaft by throwing it in a vise.
Ps: remember yamaha is regular thread and Kawasaki is reverse thread.
Been a while since I took a kawasaki prop off but if I remember correctly I used a coupler tool to hold the shaft, reoved the nsse cone on the pump and spun mine off with a wrench from the backside of the pump.
