freestylegeek
waiting...
- Grand Rapids, MI
If you think about it, it seems like if you run it that way you will have air pockets with the water flowing down...
Hence the need for a check valve. I found one on Mcmaster Carr (p/n 7933K33) that had a 1 psi cracking pressure, and barbed fittings for 3/8 line.
I'm thinking it's worth a try this summer.
My biggest concern with cooling is with the pipe though. I've always ran a hot engine and a cold pipe. The cold pipe gives me the slowest returning sonic wave (since I have a short mod chamber that I run fairly dry).
