First, the Compression, 155 psi, is too high for Pump Gas operation. Needs 105 Octane at 40:1, especially for long WOT runs.
Second, with a 2.0 N/s and 90 gr Spring, should have a Pop-Off Pressure of about about 25 psi. This is about right for Flame Arrestors on the GP1200 Engine.
I've run a Group K Ported Pump Gas GP1200 Engine with Stock Carbs w/ FA's with each having it's own dedicated Pulse Line from the Crankcase. And with only ONE Fuel Supply Line from the Tank to the Rear Carb and the Return Line out of the Front Carb. OEM Jumper Hoses 'tween Carburetors.
Can't remember the Jetting. Would have to crack open the 44's to see what Jets are in it. And the Center Carb High Speed Screw gets ONE complete turn out more than the Front and Rear Carbs.
Note that Group K added a Cooling Water Bypass to the Center Cylinder Head.
