i was skeptical about por-15, but figured it was worth trying. the white you see by the exhaust hole is fiberglass dust from enlarging the hole for a blowsion exhaust outlet.
the paint its self was strange, it seemed oily, almost like a stain when applying it, but it hardened up really tough. i had a tad left over in the paint cup i used, so i let it dry for about 2 days, then pored a bit of gas in it and let the gas sit in the cup on the paint for about 24 hours. poured the gas out and the paint was unaffected.
how will it hold up? time will tell. i still need a few things to get this hull together for next season.
on a side note, the POR-15 people sell a product called "marine clean". its used for degreasing before painting. I used it and it worked REALLY good. So good that i wish i would have worn gloves while using it, because it was strong enough to burn pinholes into my hands. high level of potassium in that stuff, if you do use it, wear gloves and use with caution. took my hands a few weeks to heal up.
