- Springfield, MO
So, with my curiosity piqued, I decided to run out to the garage and check out a bendix that I had lying around. The part with the gear, the clutch, is not serviceable from what I can tell. I'm not 100%, but it feels like a roller clutch drive. Roller clutches have hardened rollers and springs that pinch in one direction to stop movement and roll freely in the other direction. Probably 5 sets of rollers and springs. Even if you get the cap off, you'll never get it back on reliably. If the drive spins freely in both directions, the housing or the gear shaft (pinion) is shot. At work, we don't remanufacture small drives, we replace them 100% with new.
Also, I measured the shaft where the circlip goes and it looks like its 15mm. I looked around and it looks like a Delco 15MT/20MT/30MT circlip (retaining ring) will fit it. Any starter/alternator shop will have tons of these. Probably under $1.
