Installing 62t ProTec Intake Manifold
Went to install ProTec intake mani and it quickly became apparent the stock 4 bolts won't fit on the top. I figure my two options are either cut the top of each hold so it will slide up (like the top of a factory pipe exhaust mani) OR install studs and use nuts.
What have people done?
Roseand
The Weaponizer
Wisconsin
If you want to go local and get it asap and the stud route is all that works, and your hardware store doesn't have any.. Look for full length threaded bolts . Worse case scenario you cut the heads off and make your own studs
