Round 3000000 and 1 ...
Swapped out the ignition thinking it was a dying TL Flame brain. Wrong. Same symptoms. I used mcdogs oem 62t ignition/stator/flywheel. Water test was exactly the same results. Feels crisp initially and then goes lean on front cylinder like it's only firing one cylinder. Spark is equal. Starts and idles fine. On the trailer it sounds great and is super crisp. Once in the water for 30-60 seconds it falls off.
One caveat is that when I pulled my TL system I noticed a small round piece of metal pinballing around inside the flywheel housing. It was a perfectly round piece and exactly the same diameter as one of the magnets on the ATP flywheel? I inspected the flywheel and all the magnets looked to be in place. If it wasn't inside the flywheel housing I would have said it was the tail end of a bolt that just sheared off. I inspected the flywheel area and looked for obvious damage and couldn't find any. The leak down test would have picked up a leak inside here...I think. Crank seal was good too.
After that, I pulled the head off to inspect. I couldn't find any signs of water intrusion. The rings looked to be in good shape as well. I'm assuming the negative leak down test confirmed all my top end orings and gaskets are tight.
I'm seriously stumped. Most likely, I'll pull the entire engine out and inspect the flywheel housing ultra close. I sprayed soapy water everywhere on the leak down to help spot obvious leaks. Negative though.
