SXR Internal fuel fill??
Jersey
Anyone running the Blowsion dual pick up internal fuel fill? Is it worth it, does it have the basket filters at the bottom of the pick ups? If not do I need to run inline filters?
I am thinking about it for my stock SXR, I don't want to remove the external just allow me to get more gas into the tank.
Texan33
Yacht Wakes Hunter
Texas
IMO, it's not worth 170 bucks to have extra 1/4 gallon of gas in your tank if you are keeping the external.
I recently got tired of spilling gas into the lake and got a blowsion fuel filler . Cut the pickup tubes and spliced on the stock strainer/filters with fuel line . Will rework that with some seadoo type filters , same as cold fusion uses on theirs What I don't like about it is the filler opening that won't fit a 1 inch o.d. gas can spout because of the way it is made . Will have to break out the porting tool and grind it as well as look at thinning down the o.d. of the spout .
I sure wish cold fusion made one like I have on my superjet .
One big difference kawi to yami is , yami gas cap is male threaded into filler where kawi has female cap .
djkorn1
kidkornfilms
Cleveland Ohio
I made my own internal fuel fill out of the parts already on the tank...basically switched the fuel fill and the pick ups and heated up and bent the straws with a lighter...works fine, but I wish it was still on the outside...much easier than ripping my hood off all the time to fill up.
Martin33
LIVE ACTION !
Azle, Texas
The stock filler necks have been known to crack and leak water (mine did anyway), i have my blowsion fuel pickup and personally like it alot.
Daniel
