Is 760 EX manifold gasket different from 701?
Idaho
The exhaust gasket that came with my B pipe doesn't line up right on the top side of my ported 760 cylinder. Are the gaskets supposed to be the same or do I need a 760 gasket? I can cut my own if it is somehow weird with the porting. Thanks.
Jr.
Standing Tall
Staff member
Hot-Lanta
The gaskets are the same out side of the bolt holes The 701 is m6 and the 760 is m8 If your ported cyl is showing off? Then you will need to port match the gasket
I believe the 701 is m8 and 760 is m10 isn’t it?
