- Louisville, Ky
I have a 62T cylinder that i need to replace. the sleeves measured about 85.4 mm. would that mean its a 760?
so im getting ready to order an engine from sbt. and i need to buy an oem head since i have an aftermarket one. do i order a 701 head or 760? i mean i cant order a 760 since i dont really have 64x 760 cylinders.
62T cylinder is a 760cc
61x is 701cc
Hey slut aren't there 701 62T cylinders also?:dunno:
the way I understand it is:
61x - 62t cases both come w/ 61x cyls = 701cc
I could be wrong..
62T cylinder -760
61x cylinder -701
Single carb 701 - X cases, X cylinders
Dual carb 701 - T cases, X cylinders
True, but isn't there a 62t case with a 62t cylinder that is a 701 also.
Didn't the 701 raider come with that combination?
yes... i have one 62t cased, 62t 701 cylinder (oem).
62T cylinder -760
61x cylinder -701
Dual carb 760 - T cases, T cylinders, yamaha calls it a 64X
